  • latino07 Friend
    #171969
    Hi:
    I want to use JFB Comments (Facebook). How I can disable other comments options?
    TIA
    jooservices Friend
    #430463
    What else Comments system using on your site ?
    latino07 Friend
    #430578
    HI:
    As I said. I am using JFB Facebook module for comments. Unless facebook comments is added to Joomla Art Comments, I will use that instead.
    TIA
    jooservices Friend
    #430589
    I’m sorry but still confuse your question.
    If you are already using JFB Comments so what else comments on your site ?
    By self JA Voice don’t have comments. It’s using JA Comments.
    Thank you
This topic contains 4 replies, has 2 voices, and was last updated by  jooservices 12 years, 11 months ago.
