August 20, 2010 at 11:06 am #153668
How to disable “CPANEL” on top right hand side? I find a preview , but I can’t find out the module on the joomla system.
Please help…
August 20, 2010 at 3:28 pm #353273I would like to know this too, please. It is a nice feature but m customers should see our brand not something they choose. Perhaps there ist a possibility, to make the size features available, only.
kevinvinci Friendkevinvinci
- August 2010
- 4 times in 3 posts
August 20, 2010 at 3:45 pm #353276Hi,
You can disable the CPanel in Administration.
1) Log in to Administration
2) Go to Extentions -> Template Manager, then click on the JA_Droid3) On the right hand side, click on the Profiles Tab
4) Set all options of User Tools to “Hide”
5) Done! The CPanel gone
- August 20, 2010 at 4:46 pm #353277
Thanks, that was great an I am a big step further to be glad. I think at the beginning there are much differences to the standard joomla template management, so we both didnĀ“t match “user Tools” and “cpanel”. Perhaps you integrate a (cpanel) in the alt Text of the (?) description. Nice Weekend.
August 20, 2010 at 5:01 pm #353278Thank you for both the question and the reply. I would have forgotten about that. I think I’m going to experiment with this locally first to get an understanding of everything.
August 26, 2010 at 6:03 am #353722I have done as instructed but the cpanel still displays….. also I cannot get the color to permenantly change to green… it just seems to default back to default (blue) on other computers..need help urgently with this please
August 29, 2010 at 8:35 pm #354051Yes, I have gone through these steps as well, and the cPanel link is still showing.
Any other suggestions?Saguaros ModeratorSaguaros
August 30, 2010 at 3:09 am #354073<em>@longview 192087 wrote:</em><blockquote>Yes, I have gone through these steps as well, and the cPanel link is still showing.
Any other suggestions?</blockquote>The kevinvinci’s soluton is the rightly solution, it worked on my demo. Now you try once more, You turn on the “Development Mode” and you make sure that you edit the “user tools “‘s confiugrations on the current profile ( which is used as default of the site ).
- August 2010
August 30, 2010 at 4:11 am #354086<em>@longview 192087 wrote:</em><blockquote>Yes, I have gone through these steps as well, and the cPanel link is still showing.
Any other suggestions?</blockquote>Hi, Did you clear the web browser’s cache? Or can you try to use another web browser to see if it’s Ok?
August 31, 2010 at 12:18 pm #354245I have followed the instructions but with himself not to clear cpanel.
http://www.clasificadosgramenet.es/
it does not work:confused:
galaxist Friendgalaxist
- May 2010
- 2 times in 1 posts
September 3, 2010 at 2:27 pm #354534Had the same problem:
– color theme didn`t change
– cPanle didn`t go awaySolution: I have`t used the right profile. Go play with the profile, I used the DEFAULT profile after I created new ones.
But after all I used the Default-Profil and all the changes where shown right away…
September 4, 2010 at 8:42 pm #354642Hi All,
I’m struggling with this same issue. I’m able to set all the user tools to “hide”, but when I hit the “apply” button, my machine goes into an infinite loop and the changes are not saved. I have to manually close the page to continue working.
If this is a permissions problem, what path/file would I need to change to keep the updates to the default profile?
Thanks in advance for your help.
steinar Friendsteinar
- July 2007
- 98 times in 84 posts
September 4, 2010 at 10:00 pm #354645The reason for your trouble might be that you haven’t entered your ftp user name and password. If you find a horisontal layout across the browser window when you are going to edit the template, try this:
1) Enter your ftp details. Click apply, then close.
2) Go back to edit the template again. Now you will most likely find the ftp fields gone and a vertical layout which works.It did work work for me. I hope it works for you as well.
Laura Rubino FriendLaura Rubino
- 15 times in 14 posts
September 5, 2010 at 3:43 am #354652It works, but if it doesnt hide it using css ( display:none;)
AuthorPostsViewing 14 posts - 1 through 14 (of 14 total)This topic contains 14 replies, has 12 voices, and was last updated by Laura Rubino 14 years, 3 months ago.
