  • klsingh78 Friend
    #169088
    I would like to display a photo gallery, Latest news, most read like the one on the demo template, but have no idea what must be done with the plugin and what moduel should be used.
    Please help
    himangi Friend
    #415646
    Please go through the userguide for JA Teline template for Joomla 1.6 at http://www.joomlart.com/forums/topic/userguide-ja-teline-iv-for-joomla-2-5/
    The link gives details about how demo has been setup. All the module and plugin settings are explained there.
    Let me know if you need any further help.
    klsingh78 Friend
    #415656
    Thanks for the documentation , its really informative but where to enter the HTML Code given in the documentation.
    <<p>{jatabs type=”modules” animType=”animNone” style=”teline_iv” position=”top” widthTabs=”auto” heightTabs=”auto” width=”auto” height=”auto” mouseType=”click” duration=”1000″ colors=”10″ module=”ja-tabs1″ }{/jatabs}</p>
    himangi Friend
    #415658
    You need to create a custom HTML type of module, in which you need to paste the code. Before pasting it, use the Toggle Editor button at the end of the editor and then paste the code, since it is an html code.. Make sure you choose the module Position : col-mass-top and specify module Suffix : -tabs Then save the module and the content should appear on the site frontend.
This topic contains 4 replies, has 2 voices, and was last updated by  himangi 13 years, 2 months ago.
