  • dfirsching Friend
    #1070090
    The standard JA Biz template installation apparently does not include support for the Position-1, Position-2, Position-3, Position-4 positions.
    I have looked in the blocks folder and don’t see that anywhere.
    Where can I get the code that will support the positions? I have masshead.php, footer.php, etc., but there must already be code for such a block without writing it.
    Thanks!
    Pankaj Sharma Moderator
    #1070111
    Kindly check with the layout you are using in the template style.
    Select the feature intro layout for Homepage template style to use these positions.
    dfirsching Friend
    #1070317
    Thanks, but no, that doesn’t do it for me.
    I would expect that when I select features-intro it would perhaps show those positions in a row in a block just as it does for footer-1, footer-2, etc. down in the footer block.
    If I go look at features-intro.php, it just has no mention of anything loading those positions either, as pasted below. I think I need a piece of code that would let it show those positions… well, in any case I can’t seem to do something that will have them show in the user interface!
    <?php
    • Mainbody 3 columns, content in center: sidebar1 – content – sidebar2
    // detect layout
    $this->loadBlock(‘mainbody/no-sidebar’);
    dfirsching Friend
    #1070322
    I should add that yes, I can click on a block and select a position, but I can only select Position-1 OR Position-2 OR Position-3, not have a row that includes a set of those positions (as the demo displays) and as the footer block displays.
    Maybe I’m missing something, but how do I achieve enabling a row of those positions?
    Thanks for your assistance!
    #1070380
    Kindly share a temp super user details of site in private reply.
    I will have a look on it.
This topic contains 4 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years ago.
