Viewing 14 posts - 16 through 29 (of 29 total)
  • Pankaj Sharma Moderator
    #719746
    <em>@timtecsa 499711 wrote:</em><blockquote>@pankajsharma It didn’t seem to help, but in Inspect Element I tried to put it in place of the huge number and that worked – see below.
    but how to use it?
    </blockquote>
    Kindly add the code i provided to temporary fix the issue . I checked it on your site its working >> http://prntscr.com/8wb039
    #753060
    but how to use it?
    </blockquote>
    timtecsa Friend
    #719751
    It is in custom.css
    Sometimes it works but not always for me in Chrome eg: http://b24d.ads-gpm.com/index.php/politique/31-uk-politics/53-a-woman-problem
    If when it works you refresh the page, the space re-appears.
    timtecsa Friend
    #753065
    It is in custom.css
    #719765
    Also Try this code in custom.css
    .view-article .item-main { min-height: auto!important; }
    If this does not work , kindly wait for development team to fix this bug .
    #753079
    timtecsa Friend
    #719771
    Well done. That seems to work fine. I’ll test more and get back to you if it comes back. Thanks again.
    timtecsa Friend
    #753085
    timtecsa Friend
    #720740
    @pankajsharma I found another instance of ‘no mans land’ in blogs between comments and footer. See:
    http://b24d.ads-gpm.com/index.php/blog-post/198-lacinia-faucibus-consectetuer-vestibulum
    timtecsa Friend
    #753410
    cursoblue Friend
    #721506
    TIM – hi. I saw your website and I notice your SHARE THIS buttons are working fine. 🙂
    Could you help me? Mine are not shown properly.
    Thanks you very much! 🙂
    cursoblue Friend
    #753757
    timtecsa Friend
    #721514
    timtecsa Friend
    #753765
This topic contains 29 replies, has 4 voices, and was last updated by  timtecsa 9 years, 2 months ago.
