  • christofferl Friend
    #969103
    See my question in the attached image.
    1. ja_dropdown_shade1
    Pankaj Sharma Moderator
    #969136
    You can apply the style code background on the container , i am not sure which part it is , you can post the URL of page , i will help you to check this .
    christofferl Friend
    #969140
    See updated question.
    #969141
    Add below code in custom.css to add a gray background
    .container-hd {
        background: #eee!important;
    .t3-mainbody {
        background: #fff;
    You have to change the bg color of each block if the gray color appear in some of the blocks since container is the parent of all the blocks .
    christofferl Friend
    #969142
    Ah, sorry for not being so understandable. What you suggest is not what I am seeking … would like to have a transition shadow. Do you understand what I mean now?
    Thank your patience.
    1. ja_dropdown_shade2
    #969277
    As i understand you want to apply the box shadow style on the container , for this you can apply the syle via custom.css file on the
    container-hd {  box-shadow: 10px 10px 5px #888888;
    Here you can see how this style work first then you can apply it on site , the above code is just an example .
    christofferl Friend
    #969365
    Unfortunately this does not work. And I still do not think I explained in an understandable way of what I’m after.
    I know from previous project that I used something like this:
    .shadow {
    -moz-box-shadow: 3px 3px 5px 6px #ccc;
    -webkit-box-shadow: 3px 3px 5px 6px #ccc;
    Any new ideas on alternative ways to solve this?
    #969394
    H
    As i understand with your screenshot its the box-shadow style only .
    You can post the URL of page where u saw that style i will help u to guide .
    christofferl Friend
    #969406
    Thank you for trying to assist me. If you look at this site http://www.aktiespararna.se/ you will see what I am trying to achieve (see also attached image).
    Any ideas or suggestions?
    1. ja_shadow1
    #969624
    there is a background image and bg colour : http://prntscr.com/ckgu0t
    You can also use the gradient background to apply such style .
    christofferl Friend
    #969738
    Please see the attached image. We are getting forward but not there yet 😉
    Hope you understand what I want to achieve. If not let me know and I will try to explain again.
    Simply, I want an edge which is softly shaded to the background image.
    1. ja_edge1
    #969743
    Dear sir
    this is the background colour with the combination of this image that is on repeat X you have to implement the same on yourself you can change the colour and image as per your needs this is all I can suggest to you in this matter।
This topic contains 11 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 2 months ago.
