  • jordank87 Friend
    #132960
    Hi how do i get the featured products module to show in position vm-fp?
    like on; http://www.joomlart.com/templates_demo.php?template=ja_mesolite
    tonyg Friend
    #268808
    <em>@jordank87 77689 wrote:</em><blockquote>Hi how do i get the featured products module to show in position vm-fp?
    :-[</blockquote>
    The simple answer is publish it in that position, if you need a step by step instruction then let me know.
    #268840
    Hi jordank87 !
    – You go to admin >> extensions >> module manager >> select Featured Products module
    – On position select box –> choose vm-fp for it and save page.2722
This topic contains 3 replies, has 3 voices, and was last updated by  Sherlock 16 years, 3 months ago.
