August 27, 2012 at 8:05 pm #180286
I’m on the default layout, which I thought was left-main-right (only right-main-left is listed as an option though), but in any case is not working for the front page, which is instead stacking everything into one column (see image below). On non-front pages, layout is ok, with a larger left column and a smaller right column. Please advise on the front page though! Also, having trouble getting the slideshow module to work and to have custom HTML show up in the top module, but haven’t finished searching for separate solutions to those problems – just mentioning in case that sheds any light on the layout problem.
We’re in Joomla 2. 5 and didn’t use Quickstart since we’re switching to this template and already have a lot of content – should I uninstall the template and then re-install in Quickstart?
Thanks in advance!
- November 2014
- 3854 times in 3563 posts
August 28, 2012 at 8:33 am #465583I have checked your site and it would be best if you try to re-install using quickstart package and sample data. I’m sure the issue will be erased.
August 29, 2012 at 5:02 am #465691The problem is we have content we’re trying to migrate. I just asked our server’s tech support and they reported this would not work, our content would get messed up. There must be another way?
- November 2014
August 30, 2012 at 3:47 am #465790If possible you send PM me with admin access and ftp account. I will help you check it or bad news i will drop all data and help you re-install your site with sample data.
September 23, 2012 at 9:36 pm #467870It actually looks like it was because we were cutting off a div with a readmore – took care of that and now the layout’s working.
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by wcw2012 12 years, 3 months ago.
How to get layout to work
