  • Pankaj Sharma Moderator
    #1015835
    Hi Tim,
    Your question is not clear, as i can see all the above pages showing the same style for the Menu.
    can u share more details what exactly you want to do?
    timtecsa Friend
    #1016063
    Hi Pankaj,
    I tried to get the mainmenu bar on default style pages to look the same as the metro style homepage. But failed miserably 🙁 See attached screenshots. How to do it with custom.css?
    Tim
    1. defaultnav
    2. metronav
    #1016150
    You can do this using two ways :
    1. select metro theme for the default style http://prntscr.com/ehch9i
    2. Copy the style code of the homepage menu items from Homepage using firebug and apply the style on the default theme menu style via custom.css fiile.
      Here : http://prntscr.com/ehchzx
    timtecsa Friend
    #1016334
    Thanks, method 1 works fine.
    #1016464
    You are welcome!
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 9 months ago.
The topic ‘How to get same navbar as on Metro hompage on other default style pages?’ is closed to new replies.
