October 6, 2014 at 7:22 am #201858
Dear Team,
I would like to ask you regarding features-intro layout. Is it somehow possible to incorporate same layout into article?
I’ve tried to implement that with code added to article as follows
<div class=”row-feature row-feature-secondary clearfix inview”>
<div class=”container”>
<div class=”row row-feature-ct”>
<div class=”custom row-feature-secondary clearfix “>
<div class=”col-sm-12 col-md-6 about-us”>
<div class=”ja-animate” data-animation=”move-from-left”>
<h4 class=”row row-feature-title”>HEADER</h4>
<p>Some text</p>
</div>
</div>
<div class=”col-xs-12 col-sm-4 col-md-6 about-img”>
<div class=”ja-animate” data-animation=”move-from-right”><img src=”images/im.png” alt=”” />
</div>
</div>
</div>
</div>
</div>
</div>
but I’ve got problems with images and sizing with resolution 1024×768. What more sections are not expanded to the whole width…Could you please help?
Sincerely,
Łukaszchavan Friendchavan
- October 2014
- 1440 times in 1290 posts
October 6, 2014 at 7:30 am #551943since the article is within the container you can’t achieve this.
if we do any changes on css for this, all the article page would be affected.
please advice
October 6, 2014 at 8:46 am #551957I’m fine with that if you’re able to manage with some IDs, classes or something else that you want single section (can be single features-info) or features-info like with many sections.
Other option would be to stick to current version if images would position / scale correctly.
I’ve tried to add some trimmed picture but I wasn’t able to align it with the section edge (as it is with Daniele Zedda picture on ja_sugite demo page). There is additional padding which prevents from adding such cool look.In the end everything seems connected, I thing both scenarios might address this issue.
chavan Friendchavan
- October 2014
October 7, 2014 at 6:56 am #552074Add this code to this file: templates/ja_sugite/css/custom.css
.itemid-132 .container.t3-mainbody {
padding: 0;
width: 100%;
}.itemid-132 .item-page .article-header, .itemid-132 .item-page .clsPad{
padding-left: 40px;
padding-right: 40px;
}2. Replace this code in the article content
<h4>Flamboyage, balayage, ombre…</h4>
<p><br>Wszystkie pojęcia kryją za sobą nowoczesne techniki farbowania włosów. Nie każdy zdaje sobie jednak sprawę czym różnią się poszczególne metody i dla kogo są przeznaczone. Dlatego chcielibyśmy podzielić się z Państwem naszą wiedzą i przedstawić krótkie porównanie flamboyage, balayage i ombre. Te krótkie charakterystyki oraz pomoc naszych profesjonalistów z pewnością pomogą Państwu znaleźć idealną koloryzację na lato.</p>with
<div class="clsPad">
</div>October 9, 2014 at 6:52 am #552364thanks for the answer, I’ve added code above, but still there is some 40px gap.
I’ve prepared additional test article with location as follows:
test3/index.php/fryzjerstwo/remove-me.itemid-132 .item-page .article-header, .itemid-132 .item-page .clsPad{
padding-left: 0px;
padding-right: 0px;
but padding was still visible.What more, image is ove
What do you think is it possible to set 0px padding?What more interesting old page (test3/index.php/fryzjerstwo/koloryzacja) is now without padding but following code related image
<div class="row-feature clearfix inview">
<div class="container">
<div class="row row-feature-ct">
<div class="custom clearfix ">
<div class="col-sm-12 col-md-6 about-us">
<div class="ja-animate" data-animation="move-from-left">
<h4 class="row row-feature-title">Balayage.</h4>
<p>Wbrew potocznej opinii nie jest tym samym co pasemka.</p>
</div>
</div>
<div class="col-xs-12 col-sm-4 col-md-6 about-img">
<div class="ja-animate" data-animation="move-from-right"><img src="images/hairstylist/Balayage.png" alt="" />
</div>
</div>
</div>
</div>
</div>
</div>
occurs at the very bottom of the page.
What more image overlays text when browser window is narrow.
chavan Friendchavan
- October 2014
October 9, 2014 at 2:11 pm #552408This would be considered as customization. you can find people in joomlancers.com
you will get a good help
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by chavan 10 years, 3 months ago.
How to have features-info like layout for article?
