  • sunlons Friend
    #190759
    Hello
    May I know how to hide home’s page system output?
    If I hide
    It will have two lines
    And it sees
    http://www.joomlart.com/forums/topic/hide-content-from-homepage/
    don’t work for T3V2
    1. frontpage
    2. hide
    3. two-lines
    TomC Moderator
    #506495
    Can you provide the url of the site you’re working on?
    Ninja Lead Moderator
    #506766
    @sunlons: You can use this way to hide frontpage in JA University Template, you can follow as my screenshot
    1) Go to profile in JA University Template
    2) Open Home profile
    3) Set Hide Main content block to Yes
    4) Appear Home profile with Homepage menu.
    Don’t forget to clear cache from Admin area and check homepage on your site again.
    Let me know if it helps
    1. Home_profile
This topic contains 3 replies, has 3 voices, and was last updated by  Ninja Lead 11 years, 3 months ago.
