  • webjwn Friend
    #180816
    Hello guys,
    I am using JA_Rave on J!2.5.6
    I create 1 CONTENT plugin to let people to login before they can read the full article. I need this plugin always be executed. But when I enabled the global cache, it is bypassed – not executed.
    In the JA_Rave template->Global tab, cache->exclude: I set: plugin=mypluginname
    So How can I let my plugin not cached?
    How should Order my plugins? (Joomla ordering is not working that well, IMO).
    Thanks.
    jwn
    Ninja Lead Moderator
    #467641
    You try to disable cache for both cases:
    On default joomla:
    <blockquote>Admin area->Global Configuration->System tabs->Cache Settings (set OFF – Caching disabled)</blockquote>
    On the template:
    <blockquote>Admin area->Extensions->Template Manager->Edit JA_Rave – Default->Global Tabs ->Enable Development Mode(Yes) and Enable Template Information(Yes)</blockquote>
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 12 years, 3 months ago.
