kjlarski JATC
kjlarski
- October 2010
- 15 times in 1 posts
December 19, 2012 at 11:22 pm #183274Hi Joomlart-
I’m really loving this template… great work.
Could you please let me know if JA Wall can load articles with no images? Ideally, we’d like to simply load use a light-blue square as the backdrop when an image is not associated with a piece of content.
Could you please let me know if this is possible.
Thanks,
KevinWall Crasher DeveloperWall Crasher
- December 2011
- 361 times in 300 posts
arucardx Friendarucardx
- July 2010
- 138 times in 104 posts
December 20, 2012 at 1:26 pm #476952I will just point this out because I happen to notice it during development. For an article that has no image, JA Wall will add the css style no-image which causes the article to be set to display: none; when image view is enabled.
1 user says Thank You to arucardx for this useful post
kjlarski JATCkjlarski
- October 2010
December 20, 2012 at 5:42 pm #476974Great. I’m experiencing what Arucardx is describing. I have it set to image view by default and nothing appears. Could you please tell me know how to still display the title of the article when in image view. Is this possible?
Thanks again,
Kevinkjlarski JATCkjlarski
- October 2010
December 20, 2012 at 10:46 pm #476998Hi all-
If my previous post isn’t possible. Could you please let me know how to get rid of the image caption and all of the text beneath the title. For example, on http://nonprofitist.org/, I’m looking to only show the title name for articles without images. For articles with images, just showing image and title (no read more, no intro text, etc.).
Could you please help?
Thanks,
- December 2011
December 21, 2012 at 2:37 am #477009Hi kjlarski,
I am sorry, I though you are using default state.
As arucardx said above JA Wall have rule display none for no-image item when on ImageView mode.
You have disabled that rule on both files
– templates/ja_wall/themes/color_block/css/theme.css
– templates/ja_wall/css/template.cssHere the steps:
1. Replace
body.display-imageview .item-main,
body.display-imageview .item-image p.img_caption {
display: none;
}with
body.display-imageview .item-image p.img_caption,
body.display-imageview .no-image .item-main .content {
display: none;
}body.display-imageview .no-image .item-main,
body.display-imageview .no-image .item-main .header {
display: block;
}2. Replace
body.display-imageview .item.no-image {
display: none !important;
}body.display-imageview .item.no-image .item-inner {
height: 0 !important;
}with
/* Items without IMG in Image View */
/*display: none !important;*/
/*height: 0 !important;*/
}3. Replace
body.display-imageview.masonry-relayout .item-main,
body.display-imageview.masonry-relayout .item-image p.img_caption {
display: none!important;
}with
}body.display-imageview.masonry-relayout .no-image .item-main,
body.display-imageview.masonry-relayout .no-image .item-main .header {
display: block!important;
}That is all for template.css file and it will work with default theme.
I see you are using color_block theme, so you have to modify templates/ja_wall/themes/color_block/css/theme.css file also.They will have some similar rule. You may delete those rule instead.
For those code above, they will work with “.header” block. If you want to show the title only, you have add “display: block” for <h2> and display none for others.
Hope it helps.
1 user says Thank You to Wall Crasher for this useful post
- October 2010
December 23, 2012 at 7:19 pm #477304Hi all-
Wow – what a detailed response for customization. It’s so refreshing and wonderful to see this type of support. Many thanks for taking the time to explain and provide this level of detail. It’s very appreciated.
Kind regards,
Kevin1 user says Thank You to kjlarski for this useful post
This topic contains 7 replies, has 3 voices, and was last updated by kjlarski 12 years ago.
