renejdm Friend
renejdm
- April 2012
- 12 times in 1 posts
May 27, 2012 at 2:28 am #177586Hi,
The example K2 tag page has one brick on a wall. That’s it. The page only filters for one tag.
My question is how do you click on a tag and get bricks on a ja_wall? I can only preset one tag (which is pretty useless), so I must be missing something.
Has anyone got this working?
Rene
dave_logic Frienddave_logic
- December 2011
- 11 times in 1 posts
May 27, 2012 at 12:20 pm #455076<em>@renejdm 322322 wrote:</em><blockquote>Hi,
Rene</blockquote>
If I click on a tag in an article I do get all articles pertaining to that tag in the Wall…See below
http://www1.aerosolplanet.com/site4/index.php/itemlist/tag/UK%20Graffiti
renejdm Friendrenejdm
- April 2012
May 27, 2012 at 1:21 pm #455083Hi Dave,
Good example. What module/plugin are you using for the dropdown tags? Also, what module position are you using at the top, or did you create your own?
When I click on Hong Kong, the template formatting gets screwed. I tried this on a 22″ Desktop and a 17.3 ” Laptop. See attached.
Rene
- December 2011
May 27, 2012 at 1:51 pm #455088<em>@renejdm 322346 wrote:</em><blockquote>Hi Dave,
Rene
</blockquote>
Hi ,
I’m using the plugin from the same site you are using for your search box in the sidemenu. He does two flavours, I’m using the more basic one. The issue with the tag selection is fixable. What it is I think is that in that section I have some rss fed content where I haven’t stripped out the illegal tags. I was only using this module as a test really. The module position I created myself, content-top and content-bottom. Im just playing about really to see what I can get away with without breaking the responsiveness. I really need another position above the main menu and another dark stalled position under the aside which will act as a footer when the view is condensed. Nearly there but no expert so treading carefully.
Dave
- April 2012
May 27, 2012 at 2:00 pm #455092HI Dave,
If you can get these extra module positions working properly, please post your solution. I am sure many people would benefit from this.
Rene
In fact, I am really interested in the content-top position.
- December 2011
May 27, 2012 at 2:10 pm #455095<em>@renejdm 322355 wrote:</em><blockquote>HI Dave,
Rene</blockquote>
Hi yes, I intend to. Trying see if I can add styling to etc. I’m no php coder or CSS wizard so want to make sure I’m doing it properly first.
D
- April 2012
May 27, 2012 at 3:06 pm #455100Hi Everyone,
The default K2 tag functionality does not work with JA Wall.
Rene
Wall Crasher DeveloperWall Crasher
- December 2011
- 361 times in 300 posts
May 28, 2012 at 6:48 am #455160Hi Rene,
“Currently, wall page is supported on this type of menu: Category Blog view of com_content; Item List view of com_k2”
It is true that JAWall. JAWall support K2 free component. We does not support K2 Easy Filter.By the way, I have take a look on your site. At least I still see the content is change after I change a Tag. 😉
Regards.
- April 2012
May 28, 2012 at 1:00 pm #455226Hi Wall Crasher,
Yes I got it working but I had to do a few workarounds. In the category and item view I had to hide the tags. Then I used K2 Filter and Search for the dropdown tags.
Now it works the way I think it should. While the default tags did work somewhat, the results were not what I expected.
Maybe someone else managed to get this to work correctly.
Rene
- December 2011
May 29, 2012 at 2:51 am #455278Hi Rene,
Wow, it is good. You can share your solution to everyone. 🙂
John Wesley Brett ModeratorJohn Wesley Brett
- July 2013
- 645 times in 426 posts
July 31, 2012 at 6:56 pm #462735Did anyone think to check the K2 Parameters?
COMPONENTS > K2 then click the PARAMETERS button in the upper right?
There are tag settings included in there as well.Also to clarify, in order for tags to be created ‘on the fly’ the user would need permissions set for that…otherwise only those tags which have previously been created (COMPONENTS > K2 > TAGS) can be used and shown.
Have fun!
1 user says Thank You to John Wesley Brett for this useful post
AuthorPostsViewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 4 voices, and was last updated by John Wesley Brett 12 years, 5 months ago.
How to make K2 tags work with JA Wall…
