  • iguinee Friend
    #148851
    I am using this Rasite template with light ocean colour, Joomla 1.5.x and I would like to make it Left | Body | Right.
    How do I go about this, please?
    Phill Moderator
    #333290
    Open layout.css line 19
    .column {
    float:left;
    overflow:hidden;
    and change to
    .column {
    float:right;
    overflow:hidden;
    Should do the trick.
    iguinee Friend
    #333308
    I have tried this but it did not change anything.
    Is this the only place to change to Left | Body | Right?
    iguinee Friend
    #333310
    It has worked.
    I had to clear the cache.
    Thank you.
    peterpeter Friend
    #346932
    I tried the samething but the gutters are messed up now (space between the left column and the body is very narrow, and the space between the body and the right column is twice as wide as before). Which margin and/or padding should be adjusted?
    sweet160 Friend
    #350575
    yes i have the same issue here …
    http://www.new03.cenaf.com.ec/
    Hello all
    Pls open the template.css file: and try to find the following code:
    .ja-content-main {
    replace:
    .ja-content-main {
    margin-left:12px;
    Goodluck
    sweet160 Friend
    #350913
    yes that is the solution!
    Thanks I am really starting to like the support here…!
    stefangr Friend
    #358797
    Hello
    I have tried both your suggestions with no result..
    Can you please help me with this?
    I need the template to have 3 columns
    Left – Body – right
    Please need your assistance.
    John
    Phill Moderator
    #358821
    Did you clear your cache in both Joomla and your browser. A link to your site might help.
This topic contains 10 replies, has 6 voices, and was last updated by  Phill 14 years, 2 months ago.
