  • alssafeer Friend
    #139528
    Hi guys,
    i’m useing JoomFish for MultiLanguage and have tow Language
    Arabic
    English
    Arabic must be R to L.. so how i can make Full R to L in arabic with out Change in English
    also try to login as normal user.. i think have a problem
    Regards,
    Ahmed
    Anonymous Moderator
    #298153
    Hi alssafeer,
    Current this template does not support your idea.
    Alternatively, please take into consideration to post your requirements on Joomlancers.com to find a talent freelancer for your project.
    I am sorry for not being of much help in this case.
    alssafeer Friend
    #298161
    thank you for reply..
    i think a Design have a problem…
    I found this solution in Joomla Forom
    Use this. Copy your CSS style and rename it like this mystylecss_rtl.css and then open your file and change the text align of all your selectors from for example text-align:left to text-align:right.
    Now you have two CSS files: mystylecss.css and mystylecss_rtl.css now put this on your index.php file in the head section.
    Code:
    if ($this->direction == 'rtl'){
    echo'<link rel="stylesheet" href="' . $this->baseurl . '/templates/' . $this->template . '/css/mystylecss_rtl.css" type="text/css" />';
    }else{
    echo'<link rel="stylesheet" href="' . $this->baseurl . '/templates/' . $this->template . '/css/mystylecss.css" type="text/css" />';
    but in your template can’t control direction by template.css…
    Please help me how i can doit… both Languages is important to me
    Ahmed
    Anonymous Moderator
    #298170
    You can change the direction by my code:
    [PHP]
    $conf =& JFactory::getConfig();
    $default_lang = $conf->getValue(‘config.defaultlang’);
    if ($default_lang != ‘en-GB’){
    echo'<link rel=”stylesheet” href=”‘ . $this->baseurl . ‘/templates/’ . $this->template . ‘/css/mystylecss_rtl.css” type=”text/css” />’;
    }else{
    echo'<link rel=”stylesheet” href=”‘ . $this->baseurl . ‘/templates/’ . $this->template . ‘/css/mystylecss.css” type=”text/css” />’;
    [/PHP]
    alssafeer Friend
    #298178
    hi
    just past on index.php or what?
    you have my password can you doit for me please ant test by you
    Thank You
    Anonymous Moderator
    #298179
    Hi alssafeer,
    You must change in index.php file.
    Please find following code:
    <link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/template.css" type="text/css" />
    and change to:
    <?php
    $default_lang = $conf->getValue('config.defaultlang');
    if ($default_lang != 'en-GB'){
    echo '<link rel="stylesheet" href="' . $tmpTools->templateurl() . '/css/template_rtl.css" type="text/css" />';
    }else{
    echo '<link rel="stylesheet" href="' . $tmpTools->templateurl() . '/css/template.css" type="text/css" />';
    alssafeer Friend
    #298182
    you mean /templates/ja_zeolite/index.php
    alssafeer Friend
    #298183
    i doit…
    but i think arabic and english use template_rtl.css now!
    when i remove or rename template.css no thing change
    but whne i remove or rename template_rtl.css style not work for all lang
    Anonymous Moderator
    #298377
    Hi alssafeer,
    I think you did not change correct. If possible, please send me your ftp account via PM, i will help you to fix this issue.
    alssafeer Friend
    #298491
    PM sent!
    thanks
    alssafeer Friend
    #298830
    hello..
    I think u r forget me 🙂
    Anonymous Moderator
    #299202
    Hi alssafeer,
    I have fixed this issue.
    Please check again.
This topic contains 12 replies, has 2 voices, and was last updated by Anonymous 15 years, 9 months ago.
