November 8, 2012 at 6:25 pm #182058
I want to increase the width of right module position. How do i go about doing it? I have checked the “layout” css file but there is no clear indications of where to modify. Iam working on a local server at the moment with community plus for joomla 2.5.
Luna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
November 9, 2012 at 6:50 am #472372Hi,
Please go totemplatesja_community_plusetclayoutsdefault.xml
For topsl1 block:
<block name="topsl1" type="header-spotlight" leftwidth="57">user4,user5</block>
Reduce the value of left width as you want.
For middle block:
<blocks name="middle" colwidth="21.5">
<block name="right-mass-top">right-mass-top</block>
<block name="content-top">content-top</block>
<block name="content-bottom">content-bot</block>
<block name="right1" style="jarounded">left</block>
<block name="right2">right</block>
</blocks>
Increase the value of colwidth as you want1 user says Thank You to Luna Garden for this useful post
November 9, 2012 at 11:04 am #472394Thank you.
Will be at it later today.
November 9, 2012 at 12:47 pm #472399Hello Luna,
if i edit the following line
<blocks name=”middle” colwidth=”21.5″>
it increase or decrease the middle column. however i want to modify only the right module position for the caption of the module (custom module) to be on one line see attached picture.Thanks.
- July 2011
November 10, 2012 at 9:26 am #472482<em>@mgbcomputers 345500 wrote:</em><blockquote>Hello Luna,
it increase or decrease the middle column. however i want to modify only the right module position for the caption of the module (custom module) to be on one line see attached picture.Thanks.</blockquote>
If you increase the middle colum, then please add property width to block right2
<block name="right2" width="30">right</block>
</blocks>1 user says Thank You to Luna Garden for this useful post
November 10, 2012 at 9:37 pm #472531thank you,
my problem is solved.
mackdoyle Friendmackdoyle
- May 2012
December 4, 2012 at 4:14 am #475100Is this supported in JA Elastica? I cannot seem to get it to take effect.
- July 2011
December 5, 2012 at 6:57 am #475226<em>@mackdoyle 349072 wrote:</em><blockquote>Is this supported in JA Elastica? I cannot seem to get it to take effect.</blockquote>
Hi Mackdoyle,
Please go to thread of JA Elastica : http://www.joomlart.com/forums/forum/ja-elastica/ and post your problem there, with more details. I’m sure you’ll be helped.
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 3 voices, and was last updated by Luna Garden 12 years ago.
How to modify right module position?
