  • tempus88 Friend
    #188257
    Hi again
    Can somebody please explain how to configure modules in Teline III to place them into two columns?
    If you installed the template using quickstart then you already have installed that layout in profile main-right-left
    otherwise you can use the layout i post below
    <?xml version="1.0" encoding="utf-8"?>
    <layout name="desktop">
    <!--Extra css load for this layout-->
    <stylesheets>
    </stylesheets>
    <block name="header" type="header"></block>
    <block name="mainnav" type="mainnav" ></block>
    <block name="cpanel" type="usertools/cpanel"></block>
    <block name="navhelper" type="navhelper"></block>
    <block name="topsl" type="spotlight">user1,user2,user3,user4,user5</block>
    </blocks>
    <blocks name="middle" colwidth="20" fixheight="1">
    <block name="content-top">content-top</block>
    <block name="content-bottom">content-bot</block>
    <block name="right-mass-top">col-mass1</block>
    <block name="right-mass-bottom">col-mass2</block>
    <block name="right1">right</block>
    <block name="right2">left</block>
    </blocks>
    <block name="botsl" type="spotlight">user6,user7,user8,user9,user10</block>
    <block name="footer" type="footer"></block>
    </blocks>
    </layout>
    Anyway i think you should take a look at the T3V2 documentation HERE
    tempus88 Friend
    #495994
    works perfectly!
    many thanks and sorry for stupid question.
This topic contains 3 replies, has 2 voices, and was last updated by  tempus88 11 years, 5 months ago.
