btreynolds1 Friend
btreynolds1
- May 2011
- 2 times in 1 posts
September 19, 2011 at 1:03 pm #168717Hi..
Attached is the image of our layout.
here are the positions, which we want to create :
custom11, custom12, custom13, custom14, custom15, custom16, custom17, custom18
We were able to create custom11 and custom 12 , with this block code,
<block name="content-mass-top" type="spotlight" main-inner="1">custom11,custom 12</block>
We were able to create custom17 and custom 18 , with this block code,
<block name="content-mass-bottom" type="spotlight" main-inner="1">custom17,custom 18</block>
But we are stuck with custom13, custom14 and custom15 , custom16 .
Whats the block code to achieve this ?
Let me know.
jneubauer Friendjneubauer
- August 2011
- 23 times in 23 posts
September 19, 2011 at 6:36 pm #413680Typically modules placed in the same position will “stack” either horizontally or vertically. Try simply publishing the additional module in one of the positions you’ve already added, and see if it “stacks” for you.
If it does, you shouldn’t need to add 4 positions above and below the main content, only 2!btreynolds1 Friendbtreynolds1
- May 2011
September 19, 2011 at 6:38 pm #413682No..
They will only stack together, if you keep type=spotlight and we did that to achieve custom11, custom12 on top and custom17, custom18 on bottom.You getting my question now ?
- May 2011
September 20, 2011 at 7:34 am #413825Anyone ?
Anyone ?
- May 2011
September 20, 2011 at 8:11 am #413828Another question.
On our other template layout, we want to create positions, header1 , header 2, header 3, header 4 above the header reference .
That means, we might need to create a new reference.
So, please let me know, how we can create a new reference.
So, get me the code,
1. Create new reference.
2. Create those 4 module blocks in that new reference.I could have easily achieved header1 and header 2 with type=spotlight , but the header3 and header4 got me stuck and Im blocked.
So, let me know, how to handle this.
See attached to know what Im talking about.
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by btreynolds1 13 years, 3 months ago.
