  • ithacaindy Friend
    #173985
    Is it possible to place two banner modules side-by-side in the topbar position? I have a leaderboard and a button ad and there appears to be enough space, but the button displays above the leaderboard. Is this a case where only one module will fit in the position?
    The url: http://www.ithacaindy.com
    khoand Friend
    #438896
    You login backend > extensions > template manager > ja_nex > layout tab > edit default layout > replace the code
    <block name="topbar" type="topbar"></block>
    with
    <block name="topbar" type="spotlight">topbar-1,topbar-2</block>
    You set your position of modules are topbar-1 and topbar-2
    khoand Friend
    #440131
    Do you solve it?
    khoand Friend
    #442313
    Do you solve it?
This topic contains 4 replies, has 2 voices, and was last updated by  khoand 12 years, 9 months ago.
