  • aaron126 Friend
    #134090
    looking for an post a comment module ?
    where is it ?
    #274070
    <blockquote>looking for an post a comment module ?
    where is it ?</blockquote>
    can you say more detail ?
    aaron126 Friend
    #274099
    I am looking for a way to let people post comments on the articles they have just read.
    ps. my articles don’t convert to PDF when I click pdf icon..help please
    sgaughan Friend
    #274103
    <em>@aaron126 84277 wrote:</em><blockquote>I am looking for a way to let people post comments on the articles they have just read.</blockquote>
    You need a third party component for that. We use JomComment, but there are several others available. See the extensions directory at the joomla.org site.
    Sharon
    #274151
    Yes, please go to http://www.extensions.joomla.org to find some extensions
    sgaughan Friend
    #274153
    <em>@nguoiabcd 84363 wrote:</em><blockquote>Yes, please go to http://www.extensions.joomla.org to find some extensions</blockquote>
    Thank you for putting in the link.I tried earlier, but I got a busy wait from the Joomla site and couldn’t provide reference lonks to the resources.
    Sharon
    #274155
    #274353
    Can I mark this topic is solved ?
    sgaughan Friend
    #274360
    As far as I am concerned, this is solved.
    aaron126 Friend
    #274371
    thank you, the post a comment problem is solved thank you again
    sbaldwin Friend
    #274646
    Your question appeared two-part, so to answer your “second” question you had about not being able to “print ” when you clicked on your PDF icon inside your article, it is because this is a known issue with Joomla and not with the Telline ll template. In the Joomla.org help files they mention this bug/issue and that they will be coming out with a fix in the next release.
This topic contains 11 replies, has 4 voices, and was last updated by  sbaldwin 16 years, 2 months ago.
