  • subhav Friend
    #130301
    Hi All,
    I am new to Joomla and this template. I am finding out how i can put some color or background image around the website i.e. beofre the left module and after right module, which currently has a lot of white space. Can someone guide me how to put a image on these two portions?
    Any help would be very much appricaited.
    Regards,
    BC
    #257163
    Very good if you make some images what do you want
    subhav Friend
    #257174
    Hello Nguoiabcd,
    Many thanks for the reply.
    I have attached a sample of what i am trying to achive. Put a image around the website and also put a image just above the top menu bar which gives it a bit of fading affect wher the top bar starts.
    I would really appricaite if you could guide me as to where i can go and insert these images.
    Many Thanks in Advance,
    BC
    1973
    1. Sample-Top-Menu-Layout
This topic contains 3 replies, has 2 voices, and was last updated by  subhav 16 years, 4 months ago.
