TomC Moderator
TomC
- October 2014
- 3155 times in 2495 posts
March 28, 2012 at 3:30 pm #446136I really do not understand why the suggested modifications are not taking effect. I tested them within Firebug and they worked as they should. Are you clearing your JAT3 cache after making the changes – just in case?
shafee_howard Friendshafee_howard
- March 2012
March 28, 2012 at 8:09 pm #446212I’m unclear too.
Were you able to make ‘header’ and ‘mainnav’ actually center in the viewport? That’s great!
I cleared the browser cache — probably that’s not what you mean by the JA T3 cache. In any case the changes I made DID have an effect, just not what I want. With the margin-left of 490 the two were shifted way to the right — on my 1024×600 screen they start halfway across. . This is true in all the browsers I tried. I did try with margin-left of zero, that brings them all the way over the the left side of the viewport,
I could set a small margin that would line them up with the rest of the template, but that would only look right on a WSVGA display.
I’m looking at the served HTML (view source) and wow, there are SO many CSS files it’s hard to imagine finding any particular class declaration. I guess that’s what FireBug does.
Anyway I’d appreciate hearing where to go from here — HB
- March 2012
March 29, 2012 at 5:33 pm #446333I was just thinking, if someone were using a 1920 x 1080 display, a 940 px block with a 490 px margin would come out perfectly centered. But only w/ that resolution. — HB
TomC ModeratorTomC
- October 2014
March 29, 2012 at 5:42 pm #446335Is your site at a fixed width – center aligned?
- March 2012
April 2, 2012 at 4:55 am #446796I have width set at 930, actually. A don’t see any alignment setting, maybe I missed that. Where is it ??
Thanks — Howard Ballinger
- March 2012
April 7, 2012 at 5:20 am #447656Hi, I still need help to be able to center those two top blocks on the screen. What can I do now ????
swissa Friendswissa
- November 2011
- 717 times in 572 posts
April 7, 2012 at 6:47 am #447659Sorry for butting in here…
I tried this on my mac and the following changes helped to centre everything. Make a copy of the template.css first just in case.
@641 change the margin-left: 490px to margin:auto;
#ja-header {background: none repeat scroll 0 0 #C33;
margin-left: auto;
width: 930px;
}@698 deleting the margin-left: 490px; and adding margin-left: auto; and margin-right: auto seems to work
#ja-mainnav {background: url("../images/mainnav-bg.gif") repeat-x scroll left bottom #C33;
margin-left: auto;
margin-right: auto;
padding-bottom: 6px;
width: 930px;
}and finally for the logo @ 652 simply delete the margin-left: -30px;
h1.logo, div.logo-text h1 {font-size: 250%;
line-height: 1;
}I’m sure Tom will let us know if this is good code or not but as I said, it works on my screen so fingers crossed for you.
2 users say Thank You to swissa for this useful post
- March 2012
April 11, 2012 at 5:36 am #448074By George, you’ve got it !! (I think…)
I’ll have to check it on some other monitors to make sure it stays centered but it looks like it will. What’s the resolution on your monitor, Swissa ?? Both of my machines are at 1024px width; If I narrow the window but still keep it > 930px, the whole template stays centered 🙂
And Tom, how does this look to you ??
swissa Friendswissa
- November 2011
April 11, 2012 at 8:14 pm #448169Hi Howard,
My macbook is at 1280 and the attached monitor is at 1440 and it works on these. I really hope it works for you on other monitors. If I were you I would do one other thing and remove the map image from the red @ 646
#ja-header .main {
- background: url(../images/map-bg.png) no-repeat left bottom;
- padding: 8px 0 15px 0;
Just change to
#ja-header .main {
and if you want to lose the red altogether just delete the padding too.
#ja-header .main {
Wish you the best.
- March 2012
April 13, 2012 at 4:00 pm #448318Actually I did this
#ja-header .main {padding: 0;
}There must have been some padding inherited from upstream. Anyway good suggestion, I have what I wanted — thanks. And on to the next hurdle (I’ll start a new thread) — HB
AuthorPostsThis topic contains 25 replies, has 3 voices, and was last updated by shafee_howard 12 years, 9 months ago.
