  • galbur Friend
    #719704
    Is there a way to put body classes dynamicly to pages within fixel?
    I see there is a <body class=” “> Tag in the HTML Scource Code. But without classes.
    In this example from the JYAML-Template i have some classes:
    <body class=”is-homepage lang-de itemid-1229 option-com_content com_content-view-category com_content-category-336 category-336″>
    I just want to set some elements of the homepage display:hidden on specific Pages.
    Thank you
    Chris
    Ninja Lead Moderator
    #719877
    Hi Chris,
    Try adding the following code below
    Open templates/ja_fixel/tpls/home.php file
    find and change
    <body class="<?php echo $resClass ?>">
    to
    <body class="<?php echo $resClass ?> <?php $this->bodyClass(); ?>">
    Let me know if it helps
    #753173
    Hi Chris,
    find and change
    to
    galbur Friend
    #719890
    Hi Ninja Lead
    That worked! Perfect.
    Thank you
    Chris
    galbur Friend
    #753186
    Hi Ninja Lead
    Thank you
    Chris
This topic contains 5 replies, has 2 voices, and was last updated by  galbur 9 years ago.
