  • maestr001 Friend
    #128491
    Question on setting default article layout
    I am using Joomla 1.5x, Edenite template, internet explorer
    http://75.125.62.5/~rotarylk/index.php
    I would like to know how I can control the layout that each article is displayed.
    I would like to make my articles display consistently, with both the left navigation bar displayed on every page.
    Specifically,
    – I would like to have all the pages display like our “About Us” page, where the side nav is showing up on the left side. (http://75.125.62.5/~rotarylk/index.php?option=com_content&view=article&id=56&Itemid=53)
    – However, the side nev is missing on other articles / pages (http://75.125.62.5/~rotarylk/index.php?option=com_content&view=article&id=61&Itemid=79)
    Please advise.
    #248914
    Hi maestr001 !
    You can control the layout by way : select page display on each module .
    – You login to administrator
    – If you want left navigation displayed on every page you select extensions >> module manager –> select “left” on position filter select box. With each “left” module you go to it then set for display in all page.
    maestr001 Friend
    #248919
    Thank you hainn84!!!!
    This is certainly not inituitive and your response saved me hours and hours of figuring out!
This topic contains 3 replies, has 2 voices, and was last updated by  maestr001 16 years, 8 months ago.
