  • An LeFevre Friend
    #758506
    Hello.
    Is there a way to modify the VirtueMart Products module so that it displays products in order, by category? My client’s shop only has 9 products so ALL of them need to be displayed within their own category.
    But the way the module works, it won’t put all the products within a category together, it still separates them based on when they were entered into the virtuemart system.
    Please see attachment. You will notice the one lone purse is separated by the notebooks that were entered after it. The purse should be placed next to the other products in the same category.
    Also, see my settings in the backend.
    Thank you!
    Adam M Moderator
    #758820
    Hi @anoriginal,
    Unfortunately, this module is shipped with Virtuemart and we only adjust the layout to match with JA Cagox design. Since the module itself doesn’t have this function and we cannot do anything with development task for 3rd party extension too, you might want to try posting your question in Virtuemart forum instead.
This topic contains 2 replies, has 2 voices, and was last updated by  Adam M 9 years, 1 month ago.
