  • mwallace Friend
    #180912
    Please Help me that I’m using ez reality portal for property listing and ja wall as my default theme.
    demo.propertology.com/
    demo.porpertology.com/administrator
    username : admin
    Password : admin123
    and front end login details are
    username :michael
    Password: password
    I want to display/theme ezreality property listings in demo.propertology.com/ as per http://demo3.cuevaza.com/ likewise. but i’m not getting how to do this?
    waiting for immediate reply..
    thanks a lot.
    arucardx Friend
    #467952
    Hi, first off please remove your login information from your post. Those information should only be included in the red fields when you first create this topic as its for the staffs only.
    Secondly, your site uses the ezreality property portal for it’s content while the other demo site is simply using JA Wall in its demo state. Which is completely two different thing, thus I do not know what you are trying to create.
    Though if not mistaken, what you need is actually to use JA Wall as a template inside the ezreality property’s portal instead of using JA Wall as a template overwrite. But that would require alot of modification and custom work. See the sobipro sticky topic for example.
    mwallace Friend
    #468010
    Thanks arucardx,
    I’m not able to edit this post.. so I’ve changed the passwords.
    Yes you’re right.. I want JA wall template in EZ realty property portal.. means I want to display property listing to display as JA wall box is displaying in the front page..
    so means for this I’ve to customize EZRealty Template and overwrite JA wall template in that..
    Please let me know how to proceed with that.
    Thanks,
This topic contains 3 replies, has 2 voices, and was last updated by  mwallace 12 years, 3 months ago.
