mayke Friend
mayke
- May 2008
- 13 times in 1 posts
July 16, 2008 at 1:05 pm #130932Hello,
The example from Joomla in the EXTENSION page it works fine, but not in side Magazine menu.
Is anyone have a clue? Or there is any simple way to do and doing this:
Showing All of the Articles Index are related to menu and the category that we Click in the left modul of Telline V1.4 with the quickstart?Thank you.
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 17, 2008 at 9:42 am #260480Hi mayke !
Ariticle only can display in side content , please view last post at here to know how to create a article .
If you want create a article index display in all page on left column , there is easy way :
– You go to admin >> extesions >> module manager –> create a new module with type is “custom html” .
– You copy html code in article index in extension page then paste to html code of new module
– Set position for that module to “left” and set for it display all page.mayke Friendmayke
- May 2008
July 17, 2008 at 6:59 pm #260573<em>@hainn84 67377 wrote:</em><blockquote>Hi mayke !
– Set position for that module to “left” and set for it display all page.</blockquote>Thank you Hainn84,
I dont think so I have to create this at every page in categories under all of my menus.
Maybe what I need is to find special Articles index modules, that will be automatically updating when add new articles. I have tried like samples in joomla but it just listed the current articles, and not put the new articles has added . Maybe I was wrong, but I just need something easier as beginners….:)mayke Friendmayke
- May 2008
July 19, 2008 at 2:42 am #260799Hi Hainn84,
This issue bring me to the another solution, I found for the Article Index is : com_sectionex1.5.0.13 2 from joomla.rkuster.com.
But adding another modules in Telline brings another problems, the page is more slow on load.
Would you mind to give me information that where I can turn off or what I should do,
for the ‘Alt Text Information’ of each ‘section title’ on mouse over in the frontpage disappear?How to remove Alt Text as I found in another threads didn’t work in Telline II V1.4 :
you have to modify the file: /modules/mod_janews/tmpl/blog_item.php
ORIGINAL LINE:
<a title=”<?php echo htmlentities(strip_tags($row->introtext)); ?>” href=”<?php echo $link; ?>”>
CHANGE WITH:
<a href=”<?php echo $link; ?>”>Any clue for help?
Thank you.
This topic contains 4 replies, has 2 voices, and was last updated by mayke 16 years, 5 months ago.
