  • Tech-xml Friend
    #156715
    How to solve problem with UTF characters?
    Module (jaanimation) does not display UTF
    9808
    1. Untitled-1
    thuanlq Friend
    #364079
    You can fix as following:
    – Go to folder “mod_jaanimation” module
    – Open “mod_jaanimation.php” file
    – Go to line 37:
    $description = htmlentities($description, ENT_QUOTES);
    replace with new code
    $description = htmlentities($description, ENT_QUOTES,"UTF-8");
    Tech-xml Friend
    #364118
    thanks! Solved
This topic contains 3 replies, has 2 voices, and was last updated by  Tech-xml 14 years ago.
