  • nawdin Friend
    #164836
    I’d like to split sl1-l module position into 2. I’d like to have 3 position sl1-l sl1-m and sl1-r. How can I do that? pls help me it’s urgent.
    I’m using J1.6.3.
    khoand Friend
    #394760
    You login backend > Extensions > Template manager > ja_teline_iv > layout tab > default layout. Replace this code
    <block name="topsl1" type="spotlight" special="left" specialwidth="66">sl1-l,sl1-r</block>
    with
    <block name="topsl1" type="spotlight" >sl1-l,sl1-m,sl1-r</block>
    nawdin Friend
    #394781
    Thanks got it. 😉
    nawdin Friend
    #395116
    Hi I’d like to have control over each column width. For eg. sl1-l width=200px; sl1-m width 400px, sl1-r width=300px etc… How can I do it?
    khoand Friend
    #395227
    You replace this code from pluginssystemjat3jat3base-themesdefaultblocksspotlight.php
    <?php if( $this->countModules($pos) ): ?>
    with
    if ($pos == "sl1-l") $botsl[$pos]['width'] = "200px";
    else if ($pos == "sl1-m") $botsl[$pos]['width'] = "400px";
    else if ($pos == "sl1-r") $botsl[$pos]['width'] = "300px";?>
    nawdin Friend
    #395286
    <em>@khoand 245605 wrote:</em><blockquote>You replace this code from pluginssystemjat3jat3base-themesdefaultblocksspotlight.php
    with
    </blockquote>
    Hi I placed the code in that file, but the source in front end still show 33.3% for each column. Any idea?
    khoand Friend
    #395341
    Could you give me username+password of ftp and a link to your website? I will check it.
    nawdin Friend
    #395848
    <em>@khoand 245734 wrote:</em><blockquote>Hi,
    Could you give me username+password of ftp and a link to your website? I will check it.</blockquote>
    Hi I’ve PMed you. Have you checked my website yet?
    khoand Friend
    #395924
    Sorry about my late response. But username+password you give me is incorrect. You check and send it to me again.
    nawdin Friend
    #395935
    <em>@khoand 246517 wrote:</em><blockquote>Sorry about my late response. But username+password you give me is incorrect. You check and send it to me again.</blockquote>
    I sent it again. Pls check ur PM.
    khoand Friend
    #395966
    I solved it. I changed templatesja_teline_ivblocksspotlight.php
    nawdin Friend
    #396016
    Thanks how about the comment plugin problem?
    khoand Friend
    #396127
    I don’t understand what you said. What do you mean?
    khoand Friend
    #397198
    Your website has error: Bandwidth Limit Exceeded. When your website works normally again, you inform me.
This topic contains 14 replies, has 2 voices, and was last updated by  khoand 13 years, 6 months ago.
