  • fdr77 Friend
    #164962
    i would split the slideshow module position..in this mode is right?
    <block name="slideshow" type="spotlight" special="right" specialwidth="21">slideshow-l,slideshow-r</block>
    khoand Friend
    #395329
    Yes, it is. Do you try this?
    fdr77 Friend
    #395330
    It work fine… i would know if it will create a problem
    khoand Friend
    #395335
    Ok, you just use it. When you get problem, you just post it and we will help you
This topic contains 4 replies, has 2 voices, and was last updated by  khoand 13 years, 5 months ago.
