skillfulken Friend
skillfulken
- August 2013
- 5 times in 1 posts
January 15, 2014 at 2:43 pm #193776Hello!
I have installed the quickstart 3.2 andI have no idea what is going on because there are so many differences between the quickstart and the demo site.
By the way, all modules and everything seems ready and published. However, there is nothing on the frontpage (Please see the attached file). What should I do next? Thanks!
pavit Moderatorpavit
January 15, 2014 at 3:11 pm #518572Hi
Did you installed sample data at the end of procedure ?
If yes you can try to download again the quickstart files and repeat the installation procedure1 user says Thank You to pavit for this useful post
skillfulken Friendskillfulken
- August 2013
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by skillfulken 10 years, 11 months ago.
