  • mani.singh Friend
    #947583
    I am using the latest version of Virtue mart in Megastore. But when i turn on Search engine friendly url’s i can’t open
    sub categories.
    It shows 404 error
    Please help.
    Pankaj Sharma Moderator
    #947590
    Try to copy the htaccess.txt text and rename the new one to .htaccess, it will help allow SEF URLs.
    Hope it helps .
    mani.singh Friend
    #947805
    #947851
    Kindly set the template to default Joomla and then load the VM urls , if you have same issue with default Joomla , then there can be issue from VM , i suggest you to post the query on VM forum and let me know if with super user details and FTP details via Private reply if its working with the default Joomla template and not JA Template .
    mani.singh Friend
    #951265
    mani.singh Friend
    #951268
    #951274
This topic contains 6 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 4 months ago.
