  • mpetsos Friend
    #1049567
    I have Teline V 1.1.1 template and i try to update Joomla 3.6.5 on 3.7.3 by Auto update Joomla component and after the update done some admin tools has dissapeared like admin tool menu in articles.
    Wich is the best method to update Joomla version?
    Pankaj Sharma Moderator
    #1049654
    If the admin tool component has issue after the Joomla update, it can be issue of the extension, maybe its not ready for latest Joomla. You cN try to uodate or install the latest version of extension. Also report this issue to extension support team, so that they can look into this issue for you.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 4 months ago.
