christofferl Friend
christofferl
- January 2011
- 2 times in 1 posts
August 17, 2016 at 6:21 am #960679As see on https://www.joomlart.com/forums/topic/can-not-update-although-correct-user-and-pwd/ and acutally I have a problem that keeps repeating it self although that I have the correct user and pwd information.
As it has been in the past, someone from Joomlart, has fixed it without me really understanding how.
Now it is back and I need you assistance again.
If possible please, when you have fixed, try to add fix this if possible also in the upcoming version of JA Ext. Manger.
August 17, 2016 at 6:40 am #960685Hi
Can u reset your forum account password and then aa new password in JAEM again , save and try to upgrade , if you still face issue let me know , i will try to update it on your site .christofferl Friendchristofferl
- January 2011
August 17, 2016 at 6:51 am #960688I got this suggestion the last time and did it … but no effect that time.
Let me know if you need me to do this a 2nd time.
August 17, 2016 at 7:44 am #960703This reply has been marked as private.AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 3 replies, has 2 voices, and was last updated by Pankaj Sharma 8 years, 3 months ago.
How to upgrade problem persists. How to fix?
