Benjamin Falcon Friend
Benjamin Falcon
January 23, 2012 at 4:29 pm #173098Please see the attached screen shot. Can you show me how to embed an HTML MODULE (not articles) inside of MAIN BODY?
I don’t want to display articles in the front page. Thank you!
January 23, 2012 at 6:21 pm #435007Hi
You can use the Load Module Plug-in So you can load a Module position after you have created an article within this Syntax:
{loadposition user1}where user1 is the position where you have published your custom-html module
The main menu home item must be as Article Layout
pavit 12 years, 7 months ago.
