  • ngoard Friend
    #203863
    Hey there,
    I recently purchased JA Wall from JoomlArt, because it was the only good looking masonry template for Joomla available. The issue I have is that it is using HTML4…and from what I can see does not use Bootstrap Framework, there are bloated/useless CSS files like these: layout-hd.css, layout-mobile-portrait.css, layout-normal.css, layout-tablet.css, layout-wide.css, etc etc…that don’t make any sense…these files can be solved with a proper framework, like the rest of your templates (newer) that use Bootstrap/T3
    So my questions are as follows:
    1. Is there any where you know of that I can upgrade the coding of the template to HTML5?
    2. …or can I pay extra to have the template converted into HTML5 + Bootstrap or equivalent?
    3. …or Is there another newer template that you sell that can achieve the JA Wall type display/options?
    Please let me know,
    I was kind of disappointed with the coding, so much can be done with this template, it truly has great potential.
    Nick
    ngoard Friend
    #559784
    Just an update, I was able to take some time to completely convert the JA Wall template into valid HTML5, the only items not validating are the “longdesc” in the lazyload.php file, but these I like for accessibility access so…
    Ninja Lead Moderator
    #559863
    Its true that JA Wall template doesn’t support HTML5 likes as you mentioned. I have forwarded your request to our development team. Anyway, I am afraid for not being in the position to confirm on adding those features.
This topic contains 3 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 9 months ago.
