May 10, 2011 at 12:37 am #163792
On my website,when I try to click the different items linked on the menus on the left position of the template,the result page is,some items pages the layout shows “content+left colum+right column”, some items page it shows “left column+content+right column”, it really confused me now. Same problem with mega menu linked items (you can click several products and service items from the website main menu and see the result)
How to make the lay out always displayed as “content+left column+right column”. as shown on the home page default layout.
This is a Joomla 1.5 version site.
The above issue is solved following Hung Nguyen Duy’s advice to change admin > template manager > ja community plus > global tab > PROFILE OVERRIDE SETTINGS . Thank you. anyone could help with following issues as below?Some other small problems including:
1).on the contact us page, the words “Enter your message” does not show correctly(the word “Enter” retract too much),4)And a lot of CSS validation errors:
http://jigsaw.w3.org/css-validator/validator?uri=http%3A%2F%2Fwww.bluendless.com%2F&profile=css3&usermedium=all&warning=1&vextwarning=&lang=enkhoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
May 10, 2011 at 9:43 am #390545<blockquote>1).on the contact us page, the words “Enter your message” does not show correctly(the word “Enter” retract too much),</blockquote>
You remove this code from <joomla url>/templates/ja_community_plus/css/template.css file
.ja-contact-form .right-side {
float: right;
}May 10, 2011 at 9:46 am #390546Thank you, I will try, but could you modify the above post and do not mention the website url here, thank you in advance. I will be glad and waiting for your experts to help solve other 3 small issues.
khoand Friendkhoand
- February 2011
May 11, 2011 at 9:08 am #390744<blockquote>2). and print icon does not show.</blockquote>
You login backend–>Content–>Article manager–>Parameters
Set Icons and Print Icon are Show.
I did it for youMay 11, 2011 at 9:13 am #390747Thank you very much Khoand, I will try.
May 11, 2011 at 9:26 am #390755<em>@khoand 239779 wrote:</em><blockquote>You login backend–>Content–>Article manager–>Parameters
I did it for you</blockquote>Sorry I made a mistake and did not say it clearly, I said Print icon was wrong ,it should be FAX Icon on the contact us page.
Sorry again.
Problem should be “fax icon does not show on the contact us page” -
This topic contains 7 replies, has 2 voices, and was last updated by kennyd 13 years, 8 months ago.
