  • capirex Friend
    #195405
    Hello Joomlart World!
    I dont know if i’m posting my question in the right place, sorry if i’m being wrong. But i’ve google all over the place and still not find an answer to my problem. And here in Joomlart discussion forum i think many user who have many experience in using joomla, especially the joomlart support team. 🙂 .. so, please let me ask my problem
    First, i dont quite sure where this problem come from, is it from the Joomlart Template, T3 Framework, or from the Joomla CMS itself. The problem have arise just about 2 days ago.
    here is my site http://goo.gl/adAFGg
    sorry for the shorted url, i just dont want the site name come up in google search
    the problem is…. i’ve created new category and a menu to the category, and put an article into this category. After that i created new JA Slider module an put in the position as the screen below
    when i click to the article in the JA Slider. the article not show up in category page/ category menu, instead the arcticle is showing at the bottom the homepage (in the same page), please try at link above and make click to article in JA Slide Module
    one thing that i noticed, that url link to my article in JA Content Clide is showing category id. This category id not showed in other article url. (so this category id just showing in recently created categories and menu)
    here is the correct url picture
    i dont know what have caused this.. but this really bothering me. and i still have big cloud in my mind, and dont know how to solve this problem.
    Hopefully expert here can answer my problem, even if the problem not come from the joomla templates or t3 framework….. :((
    1. clickhere
    2. capture-wrong-url
    3. right-url
    Ninja Lead Moderator
    #525264
    In Joomla, if you want to view article individually, that article must be assigned to a menu item.
    Pls create a new menu item (or use an existing one) and assign article (or category that article belongs to) to this new menu item and also make sure that you don’t assign any module to this menu item.
    capirex Friend
    #525275
    <em>@Ninja Lead 414550 wrote:</em><blockquote>In Joomla, if you want to view article individually, that article must be assigned to a menu item.
    Pls create a new menu item (or use an existing one) and assign article (or category that article belongs to) to this new menu item and also make sure that you don’t assign any module to this menu item.</blockquote>
    thanks for replying ninja. Yes i do know about that basic joomla (item id and category id related to article), and i did assign category to the menu i’ve created… if i click direct to the menu.. all the item category related to the menu which i’ve assigned show perfectly.. but in this case… the url link to the article (inside JA Slider in front/home page) show that the url have an category id which i dont find it in other url article. I noticed that url that have category id, is just from the menu which i created recently, and this dont happen to the menu that i created long ago. Something that i do noticed that this problem might occur after i’ve installed K2 plugin, so maybe that was a bug in joomla.
    because if i created the article under K2 category, and put the K2 category into JA Slider Module, the urls to the article works perfect! and not a single problem occur! :((
    #525349
    I’m not sure if the problem on your site relates to Joomla itself or not. I will help to check further, please pm me admin and FTP credentials of your site.
    capirex Friend
    #525480
    <em>@Ninja Lead 414664 wrote:</em><blockquote>I’m not sure if the problem on your site relates to Joomla itself or not. I will help to check further, please pm me admin and FTP credentials of your site.</blockquote>
    Thanks ninja, but it seem the problem come from the joomla itself, and as your suggestion about menu item, so i created another menu called hidden, so beside main menu i’ve created another menu called hidden with same content as main menu, and assigned category to that hidden menu. Now, the problem seem to be solved, but i dont know if the problem will come again. Thanks Again Ninja. 🙂
This topic contains 5 replies, has 2 voices, and was last updated by  capirex 10 years, 10 months ago.
