July 19, 2007 at 6:48 pm #121515
Hi there,
I desperately need help to set up the slideshow module. I have became a member of this club to install the Pariiti template which goes perfect for my project. Now I have been 2 days trying to set up the parameters to work but nothing. It only shows the first image in the folder. Description and link does not show either.
Could anybody give me a hand with this pleassssseeeeee. I think this module should have a breaf explanation on how to use it, because it is not very clear.
I really thank you in advance for your help
Sonia
July 22, 2007 at 2:26 am #224784As it seems there is not support for this extensions, I have been 2 days trying to figure out how to make the slideshow module to work. If anybody is having the same problem as me, here is the solution:
in the parametres section I set my links this way:
1.jpg:caption=Bailoterapia&url=http://www.dragon-fly.es/content/view/25/30/
2.jpg:caption=Arte Terapia con Mandalas&url=http://www.dragon-fly.es/content/view/80/60/
3.jpg:caption=Kundalini Yoga&url=http://www.dragon-fly.es/content/view/22/27/
4.jpg:caption=Terapia Regresiva&url=http://www.dragon-fly.es/content/view/81/55/You have to get rid of the beginnign “sl-” of each image . If you put it this way, module works PERFECT.
ShannonN FriendShannonN
- July 2006
- 172 times in 49 posts
July 22, 2007 at 7:13 am #224793desingsm;21676As it seems there is not support for this extensions, I have been 2 days trying to figure out how to make the slideshow module to work. If anybody is having the same problem as me, here is the solution:
It helps if the extension used is in the parlitti template you had posted in the parlitti forum. not many look at the extensions thread
September 5, 2008 at 4:45 am #268860When you download the template there is a zip file called “ja_pariiti_1.0_quickstart_v1.1” you need to uncompress that file and upload manualy the folder “slideshow” to the directory “images/stories/” so at the end you will get this route “images/stories/slideshow” If you have configured all the settings as the manual said the slideshow automatically pickup the images from that folder. After that is just a matter of replace those images for your own images. it works perfect for me. http://www.sparklinhome.com
This topic contains 4 replies, has 3 voices, and was last updated by llambrano 16 years, 2 months ago.
