December 17, 2008 at 11:44 am #136312
Hello
I do not understand
I have a mod_janews_fp module problem
article are well
but when I clicked to view it entirely
it is impossible to see
I arrive on a page or there is the messageYou are not authorised to view this resource.
You need to login.thank you for your help
sorry for my Englishjoe
jay973 Friendjay973
- October 2008
- 105 times in 68 posts
December 17, 2008 at 3:25 pm #283243Hi,
It sounds like you may have your ‘Access Level’ set to registered on your articles. If you set them to public it should be OK.
Hope this helps.
Cheers,
Jason.December 17, 2008 at 6:46 pm #283260Hello jay973 🙂
thank you for your helpI am not my article ‘Access Level’ public :((
I took your example quickstart j 1.015 and I touched nothing
I just insatllé correctlyin the news or ja_news all works well
I can see articlesago when items are placed in mod_janews fp I restriction
and even connectYou are not authorised to view this resource.
You need to login.I always have the same message when I click on an article ja_news fp
joelnefar Friendnefar
- December 2007
- 42 times in 1 posts
December 18, 2008 at 4:53 pm #283393Go into your Section manager and Category manager and double check that your section and category themselves are “public”.
January 5, 2009 at 8:15 pm #284765I too am having the exact same problem. All sections, categories, and articles are set to Public. When you click on any article located in the mod_janews_fp area on the home page it states that You need to login. Down below in the article sections you can open the same exact article just fine.
Please help.
John Wesley Brett ModeratorJohn Wesley Brett
- July 2013
- 645 times in 426 posts
January 5, 2009 at 10:13 pm #284788How about someone with the problem sharing a URL so we can see what’s happening. Thanks!
John.
January 6, 2009 at 1:49 am #284813Here is the URL for the problem that I am experiencing: http://74.53.171.142/~nextgenp/
Thanks!
- July 2013
January 6, 2009 at 2:56 pm #284901This is not an answer…but an additional observation.
I went and registered on the site hoping to then be able to gain access to the FrontPage articles…but NOPE…still get the “You are not authorized…” but it did get rid of the “You need to login…”
So the issue is definately an ACCESS issue…and we’re looking for a setting that is allowing viewing only above the “Guest Level”…like Author or SuperAdministrator.
My 2 cents
John.January 6, 2009 at 5:20 pm #284945Thank you for taking a look at this.
I gave up with the 1.0 version, deleted, and installed 1.5. The only reason that I was originally going with 1.0 was for the additional tools that I know the user really wanted to have, but will make due without them.
The 1.0 version not only has problems with access levels (all content items, sections, and categories were set to public level access and still could not be viewed) but other issues as well. When unpublishing mod_jacpanel the font would re-size on the entire site to the largest font. I had to remove the font percentages in the css file.
I’ll post what I found out on the 1.5 version. But so far so good.
Thanks!
February 2, 2009 at 7:20 pm #289253So guys any progress on this issue? I’ve got exactly the same issue here! Same message while when I access the page through a ‘normal’ joomla module like latest news the problem isn’t there…
some more info: when I access through the ja news module I get this:
/index.php?option=com_content&task=view&id=173458when accessing through latest news module i get this:
/index.php?option=com_content&task=view&id=173&Itemid=452February 2, 2009 at 8:07 pm #289258another thing, ja news makes this page:
http://www.ckcmaassluis.nl/content/view/173458/
This page gives the you are not authorized error…when you put a / between 173 and 458 (like latest news makes the page) it shows correctly! So there must be a error in the php code??
This topic contains 11 replies, has 6 voices, and was last updated by ixware 15 years, 10 months ago.
