  • wwp_electroniks Friend
    #144038
    Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 2560 bytes) in /var/www/vhost/gestinvest.es/home/html/modules/mod_jabulletin/helper.php on line 308
    This message appears when open the web… please help with this
    prakash Friend
    #316902
    This article may help you find a solution to this problem
    Joomla Forum Link
    #316931
    now appears another fatal error:
    Fatal error: Call to undefined function json_decode() in /var/www/vhost/gestinvest.es/home/html/plugins/system/jawidget/widget_base.class.php on line 165
    Is this the same, what happen now?
    thanks a lot
    prakash Friend
    #316937
    hi … the json_decode () function i believe requires PHP V 5.2 & above installed on your hosting… if not update your PHP hosting…
    this may be one of the reason for the error.. a simple way to check what version of php is installed… simply create a new php file say testit.php
    and in that write…
    <?php
    phpinfo();
    then test the file on the server… by saying yoururl.com/testit.php
    you will get details
    #316955
    I do the test.php and sayme that i have PHP Version 5.1.6, another solution for my problem?
    sory for my english…
    thanks
    Arvind Chauhan Moderator
    #316959
    Dear wwp_electroniks,
    Please edit your first post and Click ” Require help from Mods/ Admin” and fill your site and ftp login details. That might help in looking in and trying to help you out. You are using Teline iii Beta right?
    Also, you can unpublish the JA Widget Base plugin from the Plugin manager for now.. so that your rest of the site loads.
    Arvind
    #318083
    Warning: require_once(/var/www/vhost/gestinvest.es/home/html/es/includes/helper.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/vhost/gestinvest.es/home/html/es/index.php on line 23
    Fatal error: require_once() [function.require]: Failed opening required ‘/var/www/vhost/gestinvest.es/home/html/es/includes/helper.php’ (include_path=’.:/usr/share/pear:/usr/share/php’) in /var/www/vhost/gestinvest.es/home/html/es/index.php on line 23
    This is my new problem…
This topic contains 7 replies, has 3 voices, and was last updated by  wwp_electroniks 15 years, 3 months ago.
