  • f06d2 Friend
    #140467
    hello,
    what happens with this module, I need to change what and where?
    thank you
    TomC Moderator
    #302112
    Did you install the Barite template using the Quickstart installation?
    f06d2 Friend
    #302895
    yes i have used the quickstart installation
    nguyenhuu quang Friend
    #302900
    pls check this file modulesmod_ja_newslightmod_ja_newslight.php
    or You can unzip MOd-ja_newslight and upload it to modules
    f06d2 Friend
    #302933
    thank
    i have change the folder…
    “You can unzip MOd-ja_newslight and upload it to modules”
    After it’s ok …:D
    #302992
    if you have soldved pls add Solved and make best unswer.
    Thank so much
This topic contains 6 replies, has 3 voices, and was last updated by  nguyenhuu quang 15 years, 8 months ago.
