November 20, 2007 at 5:58 pm #123912
My version of joomla is the 1.0.13
When i see ja_mercury template in the demo server i can see it (see picture below)http://www.inado.net/images/problem1.jpg
But how can i get the same effect in my site?
http://www.inado.net/images/problem2.jpg
I can’t see “a_bg.gif” and menu row is link ( underline ).
Originally Posted by ErikThorsen View Post
Hello. Yes, there is a solution. You are missing the “indent1.png” and indent2.png and indent3png and so on files…. Simply copy them from for example the original joomla template ( not Joomlart template ) and paste them into your template images folder. Then they will show up perfectly. At least they did with me!I trial this but I had the same problem
November 26, 2007 at 3:36 pm #233454Hi scelica,
Do you have a URL we can look at?
I’m guessing it’s a CSS issue, in that there is a class or id identifier missing, but without being able to see the code it’s hard to tell.
The CSS that is making the images appear is:
#ja-leftcol .moduletable ul li a, #ja-leftcol .moduletable_menu ul li a
So:
1. Make sure your menu is in a div where id=”ja-leftcol” (which I’m 99% sure it will be)
2. Make sure it is in a class=”moduletable” holder (div or table)
3. It should be an unordered listRemember if your menu it set to display as a table, this CSS won’t apply to it! 😉
Hope this helps!
December 5, 2007 at 2:16 am #233923I am also having a problem with this template. I want to modify it to use for our Church. I’ve installed it on a fresh install of Joomla 1.0.12 . The issue I am having is I’ve installed Jevents to include the mini-cal. Only on this template (I’ve tried several others) the min-cal does not stay within the left column. I’ve tried several other templates to verify it was the template creating the issue and it definitely is.
here the link to where I’ve setup the temporary installation Our Church Site
I really want to use this template layout as our base, but I can’t if I can’t get this to work.
Any help would really be appreciated.
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
December 5, 2007 at 5:05 am #233944Change your menu style to “Flash List” rather than “Virtical”
December 5, 2007 at 3:07 pm #233968This is the code choice for the menus:
# Choose your prefer Menu Type
$ja_menutype = 2; // 1: Split Menu; 2: Son of Suckerfish Dropdown Menu; 3: Transmenu;Which should I choose?
December 5, 2007 at 3:30 pm #233970I changed it to appear on the right and it fits now. Now if I can get the css to repsond to color changes I’m good to go. I noted in another post in the Jevents forum in regards to an older version, that I might be better to turn off the css in Jevents and move it to the main css. I’m going to try that.
Thanks for you help.
December 8, 2007 at 12:40 am #234128I to solve my problem
Menu Style –> Flat List
December 8, 2007 at 8:55 am #234141Yay! That’s great news.
scelica, if you can see how to, please change the title of this topic to:
SOLVED: I have a problem with ja_mercury template…it will help people know that they can learn a solution in this thread now! 😀
This topic contains 9 replies, has 4 voices, and was last updated by coos 17 years, 1 month ago.
