  • webtilia Friend
    #192737
    We are working on a project with the K2 component and need some filters. we decided to use “JA K2 Search”, it seems only appropriate to AJAX feature we have and it works here: http://demo.joomlart.com/joomla-extensions/index.php/ja-k2-filter
    Well, the web project we’re working on and where this “JA K2 Search” is here: http://www.proyectoswebtilia.info/caral/proyectos/actuales
    and is more active than in the AJAX module configuration, AJAX does not work.
    Attached is a screenshot.
    Can you help please?
    We are using joomla 2.5.16, gantry framework (Gantry template) and the latest version “of JA K2 Search”
    We welcome your comments.
    thanks
    1. Módulo-JAK2-Extra-fields-Filter-and-Search
    webtilia Friend
    #514398
    Hi I just did a test on my localhost, with a new “template gantry” on a new joomla also.
    Install JA K2 Seach and probe, all right, but in this project: http://www.proyectoswebtilia.info/caral/proyectos/actuales not work.
    Will there be any conflict Jquery?
    Thanks for your help
    1. Captura_00048
    Luna Garden Moderator
    #514508
    I have checked this link: http://www.proyectoswebtilia.info/caral/proyectos/actuales
    and see that, your site is loading 3 Jquery library, you should try to turn them off, leave only one.
    Then add Javascript code for noconflict, you can refer this link: http://api.jquery.com/jQuery.noConflict/
    webtilia Friend
    #514729
    Is there any video tutorial that can guide me better? Do you know of any video tutorials?, I have almost no experience working with Jquery and less resolving conflicts.
    Help please.
    #514739
    <blockquote>Is there any video tutorial that can guide me better?</blockquote>
    We don’t have one. This is a matter of individual site. You must check all extensions on your website, which load jquery, find the setting load Jquery, set it to No, leave only K2. JA K2 Filter also use Jquery library of K2.
    Since you have no experience about JS, I think you might post a new project on Joomlancer where you could hire a good developer to get it done for you.
This topic contains 5 replies, has 2 voices, and was last updated by  Luna Garden 10 years, 11 months ago.
