  • sergiosp Friend
    #189097
    Hi Dear Team!
    I have a problem with the subtitles and not know how to fix it.
    I have done what you suggest with regard to the modification of in-GB.tpl_ja_onepage.ini
    but I have not achieved this look good.
    On the other hand I need to change the color of the subtitles and not of where it could help me with these two problems?
    Kind Regards
    sergio
    If you are using another language you will need to have a new file
    languagees-ESes-ES.tpl_ja_onepage.ini
    and inside this file
    TPL_SUBTITLE_YOURMODULENAME = "YOURTEXT"
    TPL_SUBTITLE_QUIERO DONAR = "YOURTEXT"
    sergiosp Friend
    #499640
    Hi Pavit!,
    ok I’ll try to do what I say … you can tell me where to change the text color?
    sergio
    To change the text color you can edit this file templatesja_onepagecsstemplate.css starting from around line 2790 you can change this
    section 2
    .section2 .section-title h2 {
    color: #fff
    section 3
    .section3 .section-title h2 {
    color: #fff
    and so on for others sections
    sergiosp Friend
    #499744
    Dear Pavit, I have set-ES.tpl_ja_onepage.ini the file is modified, as amended gb-GB.tpl_ja_onepage.ini file, but I failed to look good the subtitles, you could look out I’ve done wrong? with that would help me a lot on my way to finish the site
This topic contains 5 replies, has 2 voices, and was last updated by  sergiosp 11 years, 5 months ago.
