  • laweb Friend
    #180314
    Hi I have this error with k2 module and JA News Pro Module:
    Warning: Attempt to assign property of non-object in /home/ /public_html/modules/mod_janewspro/helpers/adapter/k2.php on line 266
    HeR0 Friend
    #465730
    Hi Labweb
    Please make sure that module setting is correct and data is not null.
    Regards,
    gabrielanta Friend
    #466269
    I HAVE THE SAME PROBLEM :((
    Did you find how to fix it?
    I found a new release for the module, it seems that module version 2.5.0 should work.
    Do you try to update the module?
    I don´t know how to updtate it. I have download the file, but I don´t know how to proceed.
    Can any one help me about that?
    Thanks and regards!
    Gabriel
    1. ja-news-pro-ja-nex
    HeR0 Friend
    #466277
    Hi Gabrielanta
    You can upgrade module via JAEM ( JA Extensions manager component ) or install the module via Joomla Installation method.
    Note: please backup before upgrade, so that its easier to revert incase things dont seem right.
    Regards,
This topic contains 4 replies, has 3 voices, and was last updated by  HeR0 12 years, 4 months ago.
