Viewing 15 posts - 1 through 15 (of 33 total)
  • selvamurali Friend
    #166682
    Dear Team
    i have problem in t3 framwork if i am disable t3 Plug in its working well. when i am enable the T3 plug in it will make the problem.
    http://www.amudambooks.com/books.html
    Fatal error: Cannot redeclare class JPagination in /disk1/amudambo/public_html/libraries/joomla/html/pagination.php on line 625
    pritam Friend
    #403037
    Hello selvamurali ,
    To Solve Fatal error: Cannot redeclare class JPagination
    You can refer to this url :-
    http://www.joomlart.com/forums/topic/probable-t3-bug/
    selvamurali Friend
    #403042
    <em>@pritam 255607 wrote:</em><blockquote>Hello selvamurali ,
    http://www.joomlart.com/forums/topic/probable-t3-bug/</blockquote>
    no its not solve the problem
    selvamurali Friend
    #403270
    <em>@selvamurali 255614 wrote:</em><blockquote>no its not solve the problem
    Fatal error: Cannot redeclare class JPagination in /disk1/amudambo/public_html/libraries/joomla/html/pagination.php on line 625</blockquote>
    can anyone help me
    pritam Friend
    #403430
    Hello selvamurali ,
    I have checked your site and admin . In the Plugin Manager I have seen your t3 Plugin has enabled and your site is working with error . I am sending you screenshot of site and admin where t3 Plugin has enabled.
    1. Screenshot-1
    2. Screenshot
    selvamurali Friend
    #403544
    <em>@pritam 256122 wrote:</em><blockquote>Hello selvamurali ,
    I have checked your site and admin . In the Plugin Manager I have seen your t3 Plugin has enabled and your site is working with error . I am sending you screenshot of site and admin where t3 Plugin has enabled.</blockquote>
    problem is from ja_edinite template. pls check the site now
    pritam Friend
    #403550
    Hello selvamurali ,
    I have created bug report on this issue. You can check the progress of issue being resolved at the link http://pm.joomlart.com/browse/JATCTIIIVIIJOOMLAIVI-146
    selvamurali Friend
    #404124
    <em>@pritam 256304 wrote:</em><blockquote>Hello selvamurali ,
    I have created bug report on this issue. You can check the progress of issue being resolved at the link http://pm.joomlart.com/browse/JATCTIIIVIIJOOMLAIVI-146</blockquote>
    My problem not yet solved. kindly help me
    selvamurali Friend
    #404439
    any updates for me?
    pritam Friend
    #404620
    Hello selvamurali ,
    We have moved this issue to our developer, will get back to reply you once finds any solution out.
    Please wait till we find anything more about it.
    selvamurali Friend
    #407621
    <em>@pritam 257720 wrote:</em><blockquote>Hello selvamurali ,
    Please wait till we find anything more about it.</blockquote>
    How long take to time to resolve my problem. you replied me 05.08.11
    today 22-08-11.
    but my problem was not solved.
    my client need this template only thats why i am looking to u
    n6rej Friend
    #407627
    Which template are you trying to use? Your using a beta version of the T3 framework and that will often times have bugs and are discouraged in production envirorments.
    I’d recommend you switch to T3 v2.
    You can use the “quickstart” system which includes J! 1.7 or
    install just the framework itself & its associated 2 plug-ins here
    selvamurali Friend
    #407631
    <em>@n6rej 261519 wrote:</em><blockquote>Which template are you trying to use? Your using a beta version of the T3 framework and that will often times have bugs and are discouraged in production envirorments.
    install just the framework itself & its associated 2 plug-ins here</blockquote>
    i am using latest plug in only
    n6rej Friend
    #407760
    its not the plug-in itself. There are 3 parts to T3. The framework it self, the typography plug-in and the system plug-in. It the framework file that needs to be replaced.
    selvamurali Friend
    #410699
    Hi all
    kindly help i am not able resolve this problem.
    i am very feel abt bad joomlart support.
    i am installed the all of latest updates from the joomlart.
    but no one solve my problem
    problem is this the same
    so kindly help me and treat its urgent process
    thanks
This topic contains 33 replies, has 8 voices, and was last updated by  Ninja Lead 13 years, 3 months ago.
