Viewing 15 posts - 16 through 30 (of 33 total)
  • n6rej Friend
    #410942
    <em>@selvamurali 257062 wrote:</em><blockquote>My problem not yet solved. kindly help me</blockquote>
    Please disable the rpx plug-in and let me know if that fix’s it.
    selvamurali Friend
    #411218
    <em>@n6rej 265569 wrote:</em><blockquote>Please disable the rpx plug-in and let me know if that fix’s it.</blockquote>
    what is that rpx plug in- i dont install it.
    and one more thing
    today i am removed all the thinkgs. then Building again from scratch. the same issue.
    i feel joomlart peoples dont help me 🙁 very bad support.
    how long i need to wait to this issue resolved?
    n6rej Friend
    #411603
    <em>@selvamurali 265914 wrote:</em><blockquote>what is that rpx plug in- i dont install it.
    and one more thing
    .</blockquote>
    we are helping you. I’m not sure what you expect, but we’re trying to assist.
    so are you saying you used “quickstart” and it did not fix the problem?.
    n6rej Friend
    #411604
    I just looked @ your site and your not even using any of our products except for PART of the T3 framework. Your using someone else’s commercial template ( jm_business ) for the T3, and even then are not using all of T3. I’d recommend you take this up with the company you purchased your template from as its their obligation to support you.
    I’m sorry we won’t be able to offer further assistance on this issue @ this time.
    1. template
    holinsaer Friend
    #411833
    I also have encountered similar problems, do not know how to solve.
    n6rej Friend
    #411856
    <em>@holinsaer 266666 wrote:</em><blockquote>I also have encountered similar problems, do not know how to solve.</blockquote>
    you don’t mention which template your using nor if this is a new install. Can you please provide us with more information? My crystal ball is in the shop today :-[
    selvamurali Friend
    #413525
    <em>@n6rej 266408 wrote:</em><blockquote>I just looked @ your site and your not even using any of our products except for PART of the T3 framework. Your using someone else’s commercial template ( jm_business ) for the T3, and even then are not using all of T3. I’d recommend you take this up with the company you purchased your template from as its their obligation to support you.
    I’m sorry we won’t be able to offer further assistance on this issue @ this time.</blockquote>
    @n6rej
    You See i am posted this thread last few weeks.
    when i am using this template that have given that fatal error. so i am able to given error output to my clients. thats why i am moving that bbusiness template. ok
    but now i am still believe your support to work that template. but your not working on that issue 🙁
    one of the your technical team person send me a mail about my problem forward to your developer team.will solve the problem ASAP.
    but time only going. no one help me. i am sure it.
    i got the bad name from my client when i am using your template 🙁
    too bad
    Blaine Friend
    #413632
    Hi selvamuriali,
    this is probably dure to a conflict with another plug in or module.
    Please disable the extra plug ins/modules, ONE AT A TIME to see where the conflict is resolved.
    after identifying the conflicting module/plug in you should then add this code:
    noConflict=”true” to plugin code like:
    {conflicting plug in name (USE THE NAME) ... noConflict="true" /}
    I’ll await you findings.
    selvamurali Friend
    #413638
    <em>@Blaine 268890 wrote:</em><blockquote>Hi selvamuriali,
    I’ll await you findings.</blockquote>
    Dear friend
    thank you for your reply.
    but the main thing is the same problem continues from joomla 1.6 . now i am scrtach it from new installation and new things. but also the same problem.
    i also given my site information. so kindly check it and let me know.
    Blaine Friend
    #414046
    <em>@selvamurali 268896 wrote:</em><blockquote>Dear friend
    i also given my site information. so kindly check it and let me know.</blockquote>I am glad to hear you have done a new install, however, since the problem continues, can you confirm that you have disabled, ONE at a time, EACH module or plug in and looked to see if there is one that while disabled relieves the conflict?
    Please confirm this.
    Thanks!
    selvamurali Friend
    #414245
    <em>@Blaine 269373 wrote:</em><blockquote>I am glad to hear you have done a new install, however, since the problem continues, can you confirm that you have disabled, ONE at a time, EACH module or plug in and looked to see if there is one that while disabled relieves the conflict?
    Thanks!</blockquote>
    i disable all the modules. and plug ins. no improvement 🙁
    Blaine Friend
    #414294
    Hi selvamurali!
    I have escalated this matter for you.
    Thanks in advance for your patience!
    prolinhmilder Friend
    #414303
    <em>@pritam 256304 wrote:</em><blockquote>Hello selvamurali ,
    I have created bug report on this issue. You can check the progress of issue being resolved at the link http://pm.joomlart.com/browse/JATCTIIIVIIJOOMLAIVI-146</blockquote>
    Thank for sharing!!
    Anonymous Moderator
    #414420
    <em>@selvamurali 269619 wrote:</em><blockquote>i disable all the modules. and plug ins. no improvement :(</blockquote>
    Hi Selvamurali ,
    Could you pls PM me your ftp account for further check on issue http://pm.joomlart.com/browse/JAECPLGTIIIJOOMLAIVI-208 ?
    Thanks.
    Blaine Friend
    #414540
    <em>@JA Developer 269838 wrote:</em><blockquote>Hi Selvamurali ,
    Thanks.</blockquote>
    With all due respect JA Developer, there is a ticket and I would think the user details are there.
    Please be so kind as to list the fix here so that all users may benefit from it.
    Thanks Ja Developer!
This topic contains 33 replies, has 8 voices, and was last updated by  Ninja Lead 13 years, 3 months ago.
