  • mardo2k2 Friend
    #1036435
    I downloaded and installed JA TEline V, and I have problems with categories: items are not displayed when clicking on each category. It does not show them with the menus or the modules. Even with the original data of the template does not work
    Hello
    Your website is offline , we will need to look at it before answer to your questions, so could you share as private reply a temp super user account ?
    Also did you installed quickstart version ? or only template ?
    Did you follwed documentation page on how to setup menu items and modules ?
    mardo2k2 Friend
    #1036493
    Thank you. Now the site is online and yes I did the complete installation, not just the template, I installed quickstart version.
    In the original installation, with the sample data that the template brings, it gives the same error.
    On my site, I just modified the names of the categories and the menus. I did not alter the configuration and it gives me that same error
    Your website is off-line , if you want us to help you we will need to see your website before to answer, so could you share as private reply a temp super user account to your backend ?
    mardo2k2 Friend
    #1036907
    I finally found the problem: it was Artio Joomsef, a component for SEO in Joomla. Maybe it’s a compatibility issue, but I have it installed elsewhere and it works fine. Is there any extension similar to Artio Joomsef for SEO? Because Joomla submits the id of articles and categories in the url. I need an extension that allows me to control canonical url
    Hello
    Maybe you can take a look at THIS It is part of Joomlart and take advantage of the bundle offer.
    Details HERE
This topic contains 5 replies, has 2 voices, and was last updated by  pavit 7 years, 7 months ago.
